Hi Gurus:
I have the following requirement. Please let me know if this will work at all. I have two network segments
172.31.204.xxx → external vlan
172.31.208.xxx → internal vlan
When I define Virtual Server in 204 and it maps to pool members in 208, everything works fine from out side (i.e. outside of 208 and also from other servers in 204) .
However, I also have the requirement that some servers in the 208 network will need to access other load balanced servers (i.e. other 208 servers via 204). Is this possible ?
Someone suggested for the second requirement, I should define Virtual Server using 208 IP and specify internal VLAN in the Virtual Server definition.
Have you done this type of configuration? if so, I would appreciate it, if you share your experience and suggest me what would be the right path.
Thanks in advance.
Rit
