load balancing method for proxy servers take load equally in GTM added as generic hosts
HI, Need load balancing solution for appropriate loadbalancing method for setting multiple proxy servers to take load equally in GTM added as generic hosts.
I don’t fully understand your question. It will be better if you can post more information.
In GTM since it is your LDNS which makes the query instead of the client itself, if you are able to set-up local DNS in such a manner than to an extent you can. Since GTM only provide the DNS responses to clients local DNS queries hence you might not be able to get exact loadbalancing the way you get for LTM’s.
