Load Balancing from an Active-Active DC to an Active-Active DC
I’m working on a problem wherein we have a couple of data centres in an active-active configuration making use of stretched Layer 2 network to support extended VMotion that host a number of services, these DC’s are potentially using a 3rd part load balancing products.
There are also set data centres in close proximity to the data centres above in a similar configuration although we can specify what product or products are used at these locations that host service that pull information and/or receive pushed information from the services in the data centres described above.
I would like to optimise the traffic so that the services in the first data centre are always communicating with the services in the second data centre with the closest proximity…
I assume the solution will be something similar to that documented at https://f5.com/resources/white-papers/enabling-long-distance-live-migration-with-f5-and-vmware-vmotion.
Your statement is a generic description of your current setup. Can you please, explain the problem that you are running into and any solutions that you have tried ?
