Load Balancing attemping to connect to old peer IP address
I reconfigured a load balancer from another environment. Recently in the Local Traffic logs, there has been an error stating that it can’t connect to CMI peer at xxx.xx.xx.xx, port 6699. The IP is of the old configuration. I’ve check the scf file and can’t find this IP anywhere in the configuration. Is this configuration saved somewhere that can’t be seen in the SCF? Is there a way to update/remove the IP?
I should add that this is an error of the mcpd service.
In the management GUI go to Device Management >> Device Trust >> Peer List. Ensure that the correct peer is listed.
The correct peer is there and the IP address looks correct.
In the management GUI go to Device Management >> Device Trust >> Local Domain. Does it say “In Sync” under Status?
