load balancing 4 servers
I have 4 web application servers and I am successfully load balancing between them , except I want F5 to load balance only between two of these servers once the URI become(for example): http://192.168.1.80/Arch/Enj
Pretty straight forward. Create two pools: one with all four and the other with the two specific ones. Assign the pool of 4 to the virtual server and employ an iRule something like this:
    if { [string to lower [HTTP::uri]] starts_with "/arch/enj" } {
        pool special_pool
You could also use a switch:
    switch -glob [string to lower [HTTP::uri]] {
        "/arch/foo*" -
        "/arch/bar*" -
        "/arch/enj*" {
            pool special_pool
And depending on BIG-IP version you could also skip iRules and do all of this in CPM (LTM policies).
