I’ve been asked if we can send specific client to a different pool based on the X-Forwarded-For IP address. I suspect this must be done via an IRule. Any help would be appreciated.
Hi mate,
maybe something like the following
if {[HTTP::header values "X-Forwarded-For"] contains "1.2.3.4"}{
pool some_pool
you can retrieve x-forwarded-for header value by using HTTP::header command and then you can do whatever you want e.g. send to specific node (node command) or pool (pool command), etc.
HTTP::header
“>https://devcentral.f5.com/wiki/iRules.HTTP__header.ashx” target=“_blank”>">https://devcentral.f5.com/wiki/iRules.HTTP__header.ashx
HTTP::header
Thanks this worked by just ORing the other IP addresses. I was going to try and do it with a data group list which was why I was having trouble getting it to work. I’ll probably also add the real client IP in case the IP comes in not in the X-Forwarded-For. Thanks again for the help
this should be doable as a data-group - do you foresee the list of IP addresses changing often over time?
Shaggy, This is what we have so far and all works except if you do not have an X-Forwarded-For address and you are not in the Data group list you do not fall into the default pool. If you are in the list it works for both real client and X-Forwarded-For. Can you see anything here that would make it react this way? when HTTP_REQUEST { if {( [ class match [IP::client_addr] equals MY-List] )} { pool MY-pool } elseif {( [class match [_HTTP::header “X-Forwarded-For”] equals MY-List] )}{ pool TEST-pool } }
what happens to a user who is not in either data-group? is her/his request dropped, or does it go to an incorrect pool? also, is oneconnect configured for the virtual server?
We only have one data-group. If the IP is not in the data group and he hits the VS with his IP in the X-Forwarded-For his connection goes to the default VS configured pool. So it works only for the X-Forwared-For. If he comes in without the X-Forwarded-For and not in the list his connection is just dropped and he does not go to the default VS configured pool. Oneconnect is not configured. We get the same results if we do not use a list and just enter IP addresess and stipulate contains. Example contains “X.X.X.X”
We figured it out. We had set up a PRE- VS to put the X-Forwarded-For on before it hit our destination VS that had the Irule. We did this because we didn’t know if the specific clients in question would hit our site directly or through Akimia CDN. This way if they hit the destination VS and didn’t have an X-Forwarded-For tag they could still work. Running this way we could not get the IP that was not in the list to work correct. So just for the heck of it we put X-Forward-For on the destination VS and this worked. So here was the working IRule which I believe was the original post. I was under the impression that the Irule would take affect before an X-Forwarded-For IP stuffing. This is not the case and it was much easier then we were making it. when HTTP_REQUEST { if {( [class match [HTTP::header “X-Forwarded-For”] equals My-List] )} then { pool My-pool } }
have you checked /var/log/ltm? if i am correct, you would see something like this in the log. it is because HTTP::header returns null.
Dec 12 23:05:43 ve11a err tmm[14890]: 01220001:3: TCL error: /Common/qux - bad IP network address format (line 1)invalid IP match item for IP class /Common/MY-List (line 1) invoked from within "class match -- [HTTP::header "X-Forwarded-For"] equals MY-List"
to prevent it, you may try catch command.
e.g.
configuration
[root@ve11a:Active:In Sync] config tmsh list ltm virtual norf
ltm virtual norf {
destination 172.28.24.10:80
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
http { }
tcp { }
rules {
qux
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 7
[root@ve11a:Active:In Sync] config tmsh list ltm data-group internal MY-List
ltm data-group internal MY-List {
records {
1.1.1.1/32 { }
type ip
[root@ve11a:Active:In Sync] config tmsh list ltm rule qux
ltm rule qux {
set xff [HTTP::header "X-Forwarded-For"]
if { [class match [IP::client_addr] equals MY-List] } {
pool MY-pool
} elseif { not [catch {class match [HTTP::header "X-Forwarded-For"] equals MY-List}] } {
pool TEST-pool
when HTTP_RESPONSE {
log local0. "ip=[IP::client_addr] xff=$xff pool=[LB::server pool]"
/var/log/ltm
Dec 12 23:06:55 ve11a info tmm1[14890]: Rule /Common/qux : ip=192.168.207.97 xff= pool=/Common/foo
e.g.
configuration
ltm virtual norf {
ip-protocol tcp
pool foo
profiles {
http { }
tcp { }
rules {
qux
source 0.0.0.0/0
type automap
vs-index 7
records {
1.1.1.1/32 { }
type ip
ltm rule qux {
pool MY-pool
pool TEST-pool
/var/log/ltm
Hi Nitass, I tried to replicate your logic with the “catch” command but if I send traffic without an x-forward-for header my browser gets a TCP Reset and the following error message logged:
Feb 3 22:02:48 DCO-F5VE-LAB-1 err tmm[19467]: 01220001:3: TCL error: /Common/business-bell-ca-obe_irule - Could not find class remote-virtual-servers_dg (line 5) invoked from within "class match $xff equals remote-virtual-servers_dg
Here is the irule, does anything jump out at you?
put x-forward-for value into memory as a variable called xff
Check if the x-forward IP address is in data-group named remote-virtual-servers_dg
if { [class match $xff equals remote-virtual-servers_dg ] } {
pool obe-bus-bell-ca_webtier-local_443_pool
if there is no xff value in the header, the catch command will ensure we don't get a runtime error that produces a TCP Reset
} elseif { not [catch {class match [HTTP::header "X-Forwarded-For"] equals remote-virtual-servers_dg}] } {
pool http_pool_default
