Load Balance SFTP based on destination File Directory
Question that I can’t find the answer for. Is it possbile using F5 Big-IP LTM to load balance 2 SFTP servers based on the file directory part of the URI String. I.e.
Incoming:
sshftp://FTPserver.company.com:22//parent/incoming1  --> Goes to SFTP Server 1
sshftp://FTPserver.company.com:22//parent/incoming1 2 --> Goes to SFTP Server 2
Access is open (i.e. we don’t use usernames/passwords) as security is established via IPSEC tunnel prior to traffic hitting F5. This is not directly open to the internet.
Thank you all for your help.
@NathanM I do not believe this is possible because SFTP is encrypted between the client and destination pool member.
