I am trying to setup a new Virtual Server for Microsoft Workflow 1.0 for Sharepoint 2013. Does anyone have any tips or configuration docs on how to configure this? Do I need a VS for just the workflow port 12990 or the service bus as well? Any help is greatly appreciated.
You will need to create a separate pool and add the Workflow servers at either port 12290 (https) or 12291 (http). Assign either a default https/http or tcp monitor to the pool.
You’ll also need to create a standard virtual server at the IP you’ll be directing clients to, on either port 12290 or 12291, and select the pool you created as the target for the VIP. If you are doing SSL, you have to assign client and server SSL profiles, which means you’ll need to import the cert and key for you workflow server(s) into BIG-IP.
After typing all that out, I think probably the way to go is to use the f5.iis iApp template and use the appropriate ports for the virtual server and pool members. We also have an f5.tcp iApp that supports deploying in a fastl4 mode if you don’t need to decrypt the workflow traffic.
So, communication from the workflow server(s) to the SharePoint front ends is being blocked? Do you see connection attempts from the workflow servers to the SP VIP? Do you have an APM policy configured on that VIP?
I assume the workflow server is configured using the FQDN of the SP farm and the workflow servers can resolve and route to that virtual server, correct?
Yes the communication between workflow and SP is not totally blocked. It says on the Workflow Logs that the F5 VIP failed to response when establishing connection.
Yes it is using FQDN and on the Work flow we use https:(fqdn)or(IP)/etc of the VS but still on the Workflow Manager logs says Could not connect or failed to establish connection to f5 VIP.
Okay, I would first look at the BIG-IP connection statistics for the VIP. Do you see connections to the SP VIP and pool members when workflow attempts to connect?
If you do, you can add an iRule like this one to the SP VIP to log the requests and responses to verify you are seeing requests from the workflow servers:
