We recently deployed Exchange 2010 in our organization together with Big-IP LTM and APM.
I found some useful information in the exchange iapp deployment guide regarding setup of VIPs and what protocols are involved in the different exchange services.
Which loadbalancing method to choose depends on how you would like to distribute clients depending on server load; Doing simple round robin, or one of the more intelligent methods.
For RPC we use a simple tcp monitor on port 135. The HTTP based services can be monitored by a simple http monitor, or by something more specific for each service. Again, it depends on your needs.
We used the iApp template for exchange 2010 to get a basic config and then made customizations to that.
That got us up and running pretty fast with monitors and loadbalancing methods for the services we had chosen.
Deployment guide are very usefuel, you can almost totally based you configuration on those documents.
I’m deploying a two-CAS scenario right now and using only one IP address for using in 4 different VS:
1.- VS::80 only to redirecto to VS:443
2.- VS::443 for all HTTPs based Services
3.- VS::135 for non-http traffic (outlook client)
4.- VS::* for outlook client when using no-rpc ports in the same session.
Using this ONE-IP scenario makes use an iRule to define persistence based on the service accessed by the client but it’s clearly deifined on the deployment guide.
