I have installed BigIp in V-Sphere env.
during installation I configures interfaces internal, extertal to two networks in Vsphre 192.168.183.0/24, 192.168.181.0/24 respectively
if i create a virtual server having destination in external Ip range(Ex: 192.168.181.3) and with nodes running in internal ip range(ex: 192.168.183.5, 192.168.183.6) it is load balancing as expected. requests are distributed across nodes(snat configured as automap)
now i have a subnet in AWS ie.10.1.2.0/24 which is accessible from bigip machine through VPN connectivity(culr is working). Is it possible to create a node for a machine running in this aws subnet and loadbalance them using a virtual server. if i create a node for the machines in that subnet health check is passing but load balancing is not happening.
Since i configured 183 network to internal during installation am i restricted to load balance only nodes that are running in that network with IP range 192.169.183.0/24 ??? or is der any way to acheive it.
To Summarize: Is it possible to load balance two servers running in different ip range (diff vlans) Is it possible to have BIG-IP and Servers to be load balanced in different Data Centers or Cloud Providers
please share any docs that can help in achieving these things if possible
