When I put share point behind F5 any kind of list does not appear. It gives an error “list deleted by another user”. But when I access the server directly, it works perfectly fine.
Has anybody encountered such error ?
Can you supply the SP and F5 software versions please. Also, are you using the F5 to offload SSL? IS AAM configured on SP?
I’m sure I’ve seen this issue before but I can’t find anything now; I’m sure it was to do with Cache Control headers or something similar. Have you read through the documents here: http://www.f5.com/products/technology/microsoft/sharepoint-server/
If you are on BIG-IP v11.x, make sure you are using the latest greatest iApp.
Jeff
