Hello,
I’ve a problem about Link Controller about Inbound Wide-IP, my scenario of problem is..
ISPA 58.100.100.100 (Router A ISP A)
ISPB 200.100.100.100 (Router B ISP B)
F5 Link Controller, has 3 VLANs 2 for 2ISPs, and another for Internal
I’ve a 3 Virtual Server, 1 for Internal to Internet Pool (Wildcard Virtual Server) and 2 others is Virtual Server for 2 ISPs, all services.
I’ve a problem about when I finished to create Virtual Server, I go to “Inbound Wide IP” menu for create this, but Virtual Server cannot create.
Thanks for advanced
yoshijo
sorry, the attach picture is not correct, see above topic… Thanks for your kindness
greetings yoshijo -
Are you getting an error message, or is there some other problem?
/deb
Yoshijo,
I think I have seen the same issue you are describing before.
To have a Virtual Server appear in the Inbound Wide-IP you must make port/protocol specific and not all services. For instance, if you are wanting to create a www.customer.com inbound wide-IP, create the two Virtual Servers for each ISP on TCP port 80. You will then see the Virtual Server in the Inbound Wide-IP.
Hope this helps.
Chris
I am seeing the exact same problem. I have created the virtual servers however cannot assign them to a wide IP. Specifing a single port has not helped.
