Link Controller Links and WideIPs appeared in Offline status while the LC is in standby
hello,
I use 2 Link Controllers with BigIP V12.0 HF2
I have just set up the ConfSync/failover environment with both of them …
well, no so easy because of lack of lack of precise documents but it finally works
The only thing that looks strange to me is the following one :
The standby LC always shows its 2 ISP links (in the Link Controller section of the GUI) in Offline status (red) as well as all the WideIPs entries
As soon as this standby LC becomes the Active one (by testing the HA Group function for example, o by forcing manually to standby the active unit), all these Offline/Red status change to Available/Green status
So, this does not seems a true problem, but I am a bit annoyed by these red status
The 2 ISP Links are defined with bigip_link and gateway_icmp health monitors as recommended here : 404 Page not found | BIG-IP Documentation
Any idea to know if these red status may be considered as work as design or not ?
thanks in advance
Hello Joel,
I think that gtm part is not synced (gtm synchronisation was not done correctly). Please can you create a fake wideip and check if this wide ip si replicate on the standby member (I think not). If it is the case, i can help you to set sync between both member…
Regards,
