Link Controller behind firewall?
Hi
Seek to know if I can have Link Controller deployed on a BIG-IP appliance running GTM & LTM features.The catch here is that the appliance is in a DMZ and there is a firewall between the BIG-IP and the single router terminating two ISP Links? In this topology would it be possible to achieve inbound and outbound link load balancing?Would there be any limitations
Sumesh
Inbound should not be an issues as the traffic is directed down a specific link using DNS responses to manipulate the path taken. Outbound would not be possible, without performing additional configurations on both the firewall and router to manipulate the paths via NAT, and PBR. Utilizing a single router you would likely have to utilize PBR to manipulate outbound routing regardless where the LTM+GTM appliances sit.
Eric
