Is there a built in limit for ICMP responses on Big-IP? Consistently it will stop at 249 example: Sending 250, 100-byte ICMP Echos to 192.168.1.40, timeout is 2 seconds: !!! !!! !!! ??? Success rate is 99 percent (249/250), round-trip min/avg/max = 1/1/10 ms CISCO_DEVICE/sec/act
OK i found this information…: F5 has a limit to the ICMP rate which causes this droppage. Seen it before, it’s an expected feature
But can anyone tell me “where” is this rate configured and what the rate is to be expected. Additional question if the Big-IP is configured to be a router do the devices that sit behind the Big-Ip fall into the same category. As I am seeing the same type of limitation for ip addresses that sit behind the Big-ip…
Thanks in advance!
The F5 unit has a configuration database, you can see and change multiple settings there.
The 250 look to match the db key tm.maxrejectrate. There is also tm.maxicmprate that defaults to 100.
To list a key: tmsh list sys db tm.maxrejectrate
This solution has more information: 404 Page not found | BIG-IP Documentation
Also: 404 Page not found | BIG-IP Documentation
Anyway, this should be for ICMP errors. Based in Cisco documentation “Each exclamation point indicates receipt of a reply.”, so I assume echo reply.
