I want to limit the possibility of doing http POSTs to a set of know machines. All public machines must be able to do get’s on the same HTTP server.
irules are new to me so some help will be appiciated
if {[HTTP::method] eq “POST”}
if NOT { check is server is known (on IP/name) }
log event
reject request
Can someone help me get started ?
thanks
K
hoolio
November 11, 2009, 9:50am
2
You can add the client or server IP addresses to a datagroup (class) of type ‘address’ and then use the matchclass command to evaluate the address against the class. The matchclass wiki page has examples:
http://devcentral.f5.com/wiki/default.aspx/iRules/matchclass
To log from an iRule you can use the log command:
http://devcentral.f5.com/wiki/default.aspx/iRules/log
To reject a connection, you can use reject:
http://devcentral.f5.com/wiki/default.aspx/iRules/reject
Aaron
