In this episode of Lightboard Lessons, Jason covers a couple deployment options for routing traffic through an IPS tier while maintaining source IPs. The first option compresses the external and internal legs of the air gap solution onto a single BIG-IP (or pair) by using route domains. The second option splits the external/internal requirements onto separate BIG-IPs to allow for isolated vertical security zones.
Hello Jason.. can you please publish a session for fireeye and f5 integration? also want to understand the difference between both deployment : fireeye+f5 and airgap ssl..
