I am desperately trying to activate a starter edition of line rate.
I followed the steps on https://docs.lineratesystems.com/093Release_2.5/100Getting_Started_Guide/130Configuring_Licensing
and get stuck at the point where the actual license should be tranferred.
My Linerate system has a working IP configuration:
interface em0
mtu 1500
ip address dhcp
ip address 10.160.6.110 255.255.255.248
ip route 0.0.0.0/0 10.160.6.105
it can access activate.f5.com, asb.f5.com and login.f5.com without problems:
UNLICENSED:lr1.l4c bash "curl -v https://asb.f5.com/ 2>&1 | egrep '^(<|>)'; curl -v https://activate.f5.com/ 2>&1 | egrep '^(<|>)'; curl -v https://login.f5.com/ 2>&1 | egrep '^(<|>)'"
> GET / HTTP/1.1
> User-Agent: curl/7.38.0
> Host: asb.f5.com
> Accept: */*
< HTTP/1.0 302 Found
< Location: https://login.f5.com/resource/login.jsp?ctx=719748
< Set-Cookie: requestedLocation=FOOBAR; path=/; domain=.f5.com
< Server: BigIP
< Connection: Keep-Alive
< Content-Length: 0
> GET / HTTP/1.1
> Host: activate.f5.com
> Accept: */*
< HTTP/1.1 301 Moved Permanently
< Date: Mon, 18 May 2015 11:25:18 GMT
< Location: https://activate.f5.com/license/index.jsp
< Content-Length: 249
< Content-Type: text/html; charset=iso-8859-1
< Set-Cookie: BIGipServerActivate=FOOBAR
< Set-Cookie: TS01e1b080=FOOBAR; Path=/
< Server: F5
Moved Permanently
The document has moved here.
> GET / HTTP/1.1
> Host: login.f5.com
> Accept: */*
< Server: BigIP
< Connection: Close
< Content-Length: 0
< Location: /my.policy
< Set-Cookie: LastMRH_Session=FOOBAR;path=/;secure
< Set-Cookie: MRHSession=FOOBAR;path=/;secure
< Set-Cookie: MRHSHint=FOOBAR; expires=Thu, 01-Jan-1970 00:00:01 GMT; path=/
Activation is not possible. Neither automatic:
UNLICENSED:lr1.l4c bash "sudo tail -f /var/log/controller.messages"
May 18 05:03:52 LROS LROS: Installed license is invalid: Free Tier Only. --- trying fallback.
May 18 05:03:52 LROS LROS: INFO: base license is now inactive
May 18 05:03:59 LROS LROS: ERROR: Failed to obtain a license:
nor manual. In the latter case I get the error message on activat.f5.com after pasting in the dossier: Licensing Error: Legal Agreement checksum failed. You must accept the Agreement unaltered.
But I did not change the EULA at all.
Any clues? Cheers Christian
