LED status not clearing for "Unit going to standby" alert
Hi guys,
I see that the LED alert status showing solid yellow with the message in display “Unit going to standby”. I don’t see anything wrong in logs and also the failover status is standby for over 320 days.Have tried to clear the alarm multiple times remotely, but still the LED alert reappears with same message after sometime.Is this the normal LED behavior, if not what is the solution.
Below is the alert config that is triggered.
alert BIGIP_SOD_SODERR_SOD_STANDBY { snmptrap OID=“.1.3.6.1.4.1.3375.2.4.0.14”; lcdwarn description=“Unit going standby.” priority=“5”
Hi Raghu,
Can you see if the suggestion on this article helps you.
And can I assume you followed the steps in this article to clear your alerts.
Also see if the below helps,
clearlcd_alert clearlcd_critical clearlcd_emergency clearlcd_error clearlcd_information clearlcd_warning
