least verbose logging
I have a very simple iRule:
when SERVER_CONNECTED {
log local0.info “m”
this iRule appends a line to ltm like this:
Oct 1 05:07:50 tmm tmm[1756]: Rule tomtesting : m
I am trying to minimize the size of my ltm file. How can I shorten the length of this log entry?? For example, I do not need to see the text and I do not need to see the rule name, etc.
Also, is it possible to log things to another file other than ltm? I know i can syslog to a remote server. But is there an easy way to log to a special file named test.log??
In 9.4.2 and later, you can remove the rule name from the log entry using log -noname (Click here). I don’t think there is a method for removing the other parts of the log message.
Aaron
