Learn About Programmability
Your platform, your rules.
F5’s platforms are built to be programmed — not just configured. Whether you’re scripting traffic decisions at the data plane, orchestrating infrastructure through APIs, or wiring your stack into a CI/CD pipeline, there’s a first-class path for how you work. This space collects the code, guides, and community knowledge to help you go further, faster.
BIG-IP: Data & Control Plane Scripting
iRules put Tcl-based logic directly in the data path — rewrite, route, and respond to traffic without touching upstream apps. iControl REST exposes the full BIG-IP configuration surface as a clean API, while iCall lets you schedule and trigger that automation on a time or event basis. Together they cover data plane customization and control plane lifecycle management in one coherent model.
NGINX: Embedded Scripting at the Edge
Extend NGINX natively with njs — a JavaScript subset that runs inside request processing — or drop into Lua for more complex stateful logic. Both give you programmable hooks across HTTP, stream, and auth phases without forking into a sidecar.
F5 Distributed Cloud: API-First Everywhere
Every object in Distributed Cloud — from load balancers to WAF policies to service meshes — is declaratively managed through a fully versioned REST API and a Terraform provider. No click-only features. Explore the API reference or jump into the community’s collection of terraform examples to see what others are building on top of the platform.
Tooling & Ecosystem: Build, Test, Deploy
Across all platforms, F5ers and the larger community maintain tools for every stage of the lifecycle.
Explore and Learn More
