I try to address my LDAP traffic according to it belongs to a IP range or another.
I think that I can do this by this way but
I don’t know how to describe and compare range using “class” and “findclass”.
What do you think?
Andrés :-Z
class myPoolA{
“10.16.13.25” “10.16.13.48”
class myPoolB{
“10.16.13.89” “10.16.13.112”
when CLIENT_ACCEPTED {
TCP::collect
when CLIENT_DATA {
set myPoolA [findclass[findstr [TCP::payload] LOGIN-IP 9 “MSISDN”] $::myPoolA…???]
if {$myPoolA!= “”}{
pool $myPoolA
set myPoolB [findclass[findstr [TCP::payload] LOGIN-IP 9 “MSISDN”] $::myPoolB…???]
if {$myPoolA!= “”}{
pool $myPoolB
TCP::release
To perform comparison of client IP address with a list of addresses or subnets in a Data Group List (class), define your class as type “Address”, then use matchclass instead of findclass.
First define these classes as type “Address”:
class LDAP_GroupA {
"network 10.16.13.0/26"
"host 10.10.10.1"
class myPoolB{
"network 10.16.13.64/26"
"host 10.10.10.2"
Then this iRule will distribute the traffic:
when RULE_INIT {
set ::defaultPool myPool
TCP::collect
when CLIENT_DATA {
set LoginIP [findstr [TCP::payload] LOGIN-IP 9 "MSISDN"]
if {$LoginIP != ""}{
if { [matchclass $LoginIP equals $::LDAP_GroupA]}{
pool PoolA
} elseif { [matchclass $LoginIP equals $::LDAP_GroupB]}{
pool PoolA
pool $::defaultPool
TCP::release
Any request with no LOGIN-IP value or an address not in either class will go to the default pool.
HTH
/deb
(added default pool logic to previous post)
I have proved it in a probe environment and it works
thanks a lot
the request that we send is:
ldapsearch -h 10.237.0.255 -b o=SIU “LOGIN-IP=10.146.248.2” MSISDN
we can not send mask in the request.
this is the irule:
class LDAP_GroupA {
“network 10.16.13.0/26”
class myPoolB{
“network 10.16.13.64/26”
when RULE_INIT {
TCP::collect
when CLIENT_DATA {
set LoginIP [findstr [TCP::payload] LOGIN-IP 9 “MSISDN”]
if {$LoginIP != “”}{
pool PoolA
pool PoolA
pool $::defaultPool
TCP::release
We have tried in a real enviroment a it not works, it result the next error:
Jun 27 11:42:36 tmm tmm[1658]: 01220002:6: Rule LDAP_IRULE : IP Capturada: 10.146.248.200
Jun 27 11:42:36 tmm tmm[1658]: 01220001:3: TCL error: Rule LDAP_IRULE - missing "mask"Invalid class element 10.146.248.20 for class LDAP_GroupA invoked from within “matchclass $LoginIP equals $::LDAP_GroupA”
any idea to resolve this??
thanks in advantage
Looks like the class member format may not be correct.
Did you create the class as type “Address”?
Yes, muy class is type “Address”
