LDAP - Tracking Heavy Clients
Hi all,
we have are using a pair of LTM1500’s(v9.4.7) to LB LDAP 389 and 636.
I am trying to get stats on client usage.
For example what client IP’s have the highest traffic and connections.
I have looked at the CLI and bigpipe but cant find anything to provide the information I’m after.
Any help would be greatly appreciated.
Thanks in advance
Is there something in particular you’re trying to achieve?
LTM doesn’t store these types of metrics by default. It would be a little difficult to track the top X client IP’s, as that would require keeping a count of every client IP address that accesses the VIP or logging every single request to the VIP.
You could use a stats profile and iRule to collect arbitrary statistics. But whether it will work for you scenario depends on what you’re trying to do. Here is an article from Joe with a great example of using an iRule and stats profile together:
Custom Reporting with iRules
http://devcentral.f5.com/Default.aspx?tabid=63&articleType=ArticleView&articleId=66
Aaron
Thanks for the reply Aaron.
I’ll have a read of the example you posted.
What I am trying to do is at certain times of the day we see peeks in LDAP connections and requests which increases the load on the back end LDAP nodes.
The LDAP traces on the back end servers only show the IP of the LB so tracking is impossible.
So I thought If I can see clients by traffic then it might give me a better idea of the culprit.
If the connections through LTM are less then ~7k (Click here), you could dump out the connection table using ‘b conn all show all’ and parse the output to find out which are the top clients.
This would be considerably more efficient than the alternatives of trying to track all client connections. If you did want to try that route, you could use an iRule which logs (ideally remotely) all client connections. One example using a remote UDP syslog server is:
when SERVER_CONNECTED {
      Log the connection details to a remote syslog server
     log 1.1.1.1:514 local0.debug "client IP:port=[IP::client_addr]:[TCP::client_port],\
        SNAT IP:port=[IP::local_addr]:[TCP::local_port], server IP:port=[IP::server_addr]:[TCP::server_port]"
Aaron
You could also modify one of the flood protection iRules in the codeshare (like this one Click here) and just have it log the hitters over your specified max count.
Thanks for the replies, thats great.
I’ve had a play around with “b conn server show all”
which gives me a table of stats which I was after.
I’ve pumped it out to a file then scripted it into a nice format.
I’ll have a play around with the flood protection iRule in the next few days.
