LDAP login into F5 interface takes 30seconds or more
Like the subject says- we’re seeing logins take 30 seconds or more when trying to login to the F5 interface with LDAP enabled.
Using port 389.
Directory service: Windows AD LDAP -
The only thing I can think of is that we have UDP blocked and it appears UDP attempts to use UDP before it times out and uses TCP.
Anyone else have experience with this?
