I’m sure this is well documented for the lame (like myself), but I’m not seeing it.
I need to set a session variable based on an AD lookup of a users homeDirectory attribute value. Obviously I want to 1) setup a drive map 2) set a windows file favorite based on this attribute value. Can someone point me in the right direction.
Thanks smart people.
I think your requirement is not supported yet.
AD/LDAP session variables support “LAN address space” for NetworkAccess client setting, pre-logon rule, protected configuration and “URL” under Intranet Webtop.
to see all session variable, you may enable session variable dump under device management, maintenance, troubleshooting tool. the log will be shown in logon report.
syntax is always simple but it requires % (i.e. %session.ssl.on%) for NetworkAccess and IntranetWebtop. it does not require % in pre-logon/protected configuration rule…
