Hello,
I have a setup: Lan → Proxy servers (ISA) → switch-> LC-> switch ->internet Links.
Where there are three proxy servers and six internet links and these links are connected to a switch using dot1q to the LC.
i am loadbalancing outbound traffic, the default_gateway pool will be created and used as befault routes .
The customer’s requirement will be:
1- proxy 1 will have (traversing) links 1 and 2 (pool1)
2- proxy 2 will have (traversing) links 3 and 4 (pool2)
3- proxy 3 will have (traversing) links 5 and 6 (pool3)
So I have to write an iRule saying
IF the client ip address equals proxy1 → go to pool1 Else if client ip address equals proxy2 → go to pool2 Else if client ip address equals proxy3 → go to pool3
So as the below irule, will it work as it should be or do i have to add something else?
Please advice back or provide any suggestions because i am implementing this setup without prior staging…directly into production .
when CLIENT_ACCEPTED {
if { [IP::addr [IP::client_addr] equals 10.60.60.3] } {
if {[active_members pool1] < 1}{
pool default_pool
snat automap
persist dest_addr
pool pool1
snat automap
persist dest_addr
elseif { [IP::addr [IP::client_addr] equals 10.60.60.4] } {
if {[active_members pool2] < 1}{
pool default_pool
snat automap
persist dest_addr
pool pool2
snat automap
persist dest_addr
elseif { [IP::addr [IP::client_addr] equals 10.60.60.5] } {
if {[active_members pool3] < 1}{
pool default_pool
snat automap
persist dest_addr
pool pool3
snat automap
persist dest_addr
Thank you and Regards,
George
