LC-LINK Bandwidth restriction using rateclass
Two links are adsl and leased line with ADSL – 48 Mbps and LL – 16 Mbps BW respectively
Requirement:
1. F5 LC will always send http/https/DNS traffic to ADSL Link
Solution: member of ADSL router IP is set higher priority (3) in http_pool, https_pool and dns_pool.
And priority activation is enabled as less than 1 member. Member of leased line router is set lesser priority 1. So LC will always select ADSL link.
2. F5 LC will inspect if ADSL bandwidth is saturated (all 48mbps is used) or down it will then only utilize 50% (8mbps)bandwidth of the Leased Line
Solution: How to achieve this part. I created leased_linerateclass and applied this rate class to http_vs , https_vs and dns_vs using leaseline_rateclassirule. Is this a correct way. But it is not working properly.
Appreciate your comment and suggestion
LC configuration details
Link1 – ADSL weighting Ratio link ratio -1
Link2 – LL weighting Ratio link ratio -1
Gateway_pool
LB: ratio(node)
Members
192.168.2.2:0
9X.XX.XXX.XXX:0
http_pool
LB: dynamicratio(member)
192.168.2.2:80 priority 3
9X.XX.XXX.XXX:80 priority 1
priority group activation less than 1 member enabled
https_pool
192.168.2.2:443 priority 3
9X.XX.XXX.XXX:443 priority 1
dns_pool
192.168.2.2:53 priority 3
9X.XX.XXX.XXX:53 priority 1
Wildcard Virtual are as follows
0.0.0.0:80
Profile fastL4
Pool
http_pool
enabled on internal_vlan
0.0.0.0:443
Profile fastL4
Pool https_pool
irule leaseline_rateclassirule
0.0.0.0:53
Profile fastL4
Pool dns_pool
leased_line_rateclass
base 8 mbps
ceiling 8mpbs
burst size 0
direction any
when LB_SELECTED {
if { [IP::addr [LB::server addr] equals 9X.XX.XXX.XXX] } {
log local0. “[LB::server addr] was the IP that was selected.”
rateclass leasedline_rateclass
else {
discard
Regards
insitha
