in the above rule I found that the lb server chosen is the same as the one after the reselect action (the VIP has cookie presistance) but I tried to remove the presistance but it has no effect on the behavouir
so I need help here how can I force the selection of other pool members
In the case of two members in a Local Traffic Manager pool, the iRule command LB::reselect now selects the next pool member if the first pool member is unavailable, which prevents an infinite loop condition.
So an upgrade to this version should fix your issue
