Is LB::persist used to return the persistence profile in use on the current virtual server? Can anyone confirm what it’s used for and what options there are for it?
I am trying to troubleshoot an issue with persistence and ASM when using nodes defined on port 0 and saw this command in the _ASM_clientside rule.
Here are some results I got:
Testing with a standard HTTP VIP without ASM, with the default source address persistence profile:
log local0. “\[LB::persist\]: [LB::persist]”
output: : [LB::persist]: source_addr 0
log local0. “\[LB::persist key\]: [LB::persist key]”
output: : [LB::persist key]: source_addr :: 0
b persist show all output:
PERSISTENT CONNECTIONS --
Mode: source addr Value: 192.168.99.38
Virtual: 192.168.101.41:http Node: 192.168.101.43:http Age: 2sec
When I change the VIP to use cookie and source address persistence as the default and fallback persistence methods, I see:
: [LB::persist]: cookie
And here are the errors I received from the iRuler when trying to use other options for LB::persist:
log local0. “\[LB::persist\]: [LB::persist test]”
[invalid option “test” must be: key cookie] [test]
log local0. “\[LB::persist\]: [LB::persist cookie]”
[wrong args] [LB::persist cookie]
log local0. “\[LB::persist\]: [LB::persist cookie test]”
[wrong args] [LB::persist cookie test]
Thanks,
Aaron
