LB decisions matching the headers
Hi, We have a custom written application that is being hosted on multiple servers behind the LTM. It does not use cookies rather a variety of unique http headers. I need to use these unique headers to make load balancing decisions.
Below first set of headers that should hit the pool_1
TEST/Rumba/mountainisred@4
TEST/Rumba/mountainisblue@2
TEST/Rumba/mountainisorange@2
TEST/Rumba/mountainisgreen@2
Below second set of headers that should hit the pool_2
TEST/Rumba/mountainispink@2
TEST/Rumba/mountainisgray@2
TEST/Rumba/mountainiswhite@2
TEST/Rumba/mountainisblack@2
Traffic with none of the above headers to hit a default_pool pool_3
Here is my iRule:
when HTTP_REQUEST { if { [HTTP::header value mountainisred@4} {
pool pool_1 } else {
pool main_pool
Your response is much appreciated.
You can take the below irule as example, I assumed that you were talking about uri not headers but correct me if I’m wrong :
    switch -glob [HTTP::uri] {
        "*TEST/Rumba/mountainisred@4*" -
        "*TEST/Rumba/mountainisblue@2*" -
        "*TEST/Rumba/mountainisorange@2*" -
        "*TEST/Rumba/mountainisgreen@2*" {
            pool_1
        "*TEST/Rumba/mountainispink@2*" -
        "*TEST/Rumba/mountainisgray@2*" -
        "*TEST/Rumba/mountainiswhite@2*" -
        "*TEST/Rumba/mountainisblack@2*" {
            pool_2
        default {
            pool_3
            pool_1
            pool_2
        default {
            pool_3
Thanks Yann for your quick response. Nope. Its not the uri but headers. I am sure. I have seen the headers. The headers has 3 or 4 lines of unique strings. I took out one of them, that are widely looks a similar type across all the headers. Does that makes any difference if it is a POST rather than a GET.
Is it header name or values that you post ?
Hi Yann,
One of the header looks something like this.
POST /online/vendorlink/protocol/3 HTTP/1.1
Content-Type: application/x-onl-pki-smime
online.protocol.remote.contenttype: TEST/Rumba/mountainisred@4
Cache-Control: no-cache
Pragma: no-cache
User-Agent: Java/1.7.0_25
Host: host1.abc.com
Accept: text/html, image/gif, image/jpeg, *; q=.2, /; q=.2
Connection: keep-alive
Content-Length: 5836
thanks
So you can change the [HTTP::uri] command in the switch by [HTTP::header “online.protocol.remote.contenttype”]
Will this one work as well? [HTTP::header “mountainisred@4”] Please advise. thanks
Hi Yann, ignore me. Yes ,it is the name and value match. I got it. thanks
Can we supply or pass the header values from a txt file, into the iRule. The txt file to contain all the header values, tab limited etc. using internal data-group? and be made available to the iRules?
Please advise how I can achieve it.
thanks
Hi, you can pass a datagroup file by using the following command ‘class match [HTTP::header “online.protocol.remote.contenttype”] equals header_value’. header_value is the name of your datagroup.
But using datagroup, you can’t use the switch anymore, you have to use if instead.
Hi Yann,
See below. I came out with an iRule. Would this be OK. Please respond. Much appriciated.
These are string data-groups; header_value_1 & header_value_2
if { [class match [HTTP::header "online.protocol.remote.contenttype"] equals header_value_1] } {
        pool_1
if { [class match [HTTP::header "online.protocol.remote.contenttype"] equals header_value_2] } {
        pool_2
    else {
        pool_3
I would recommend the modified irule below, changed second if by elseif. Otherwise, If you match the first if you also match the else and you will have a tcl error and a tcp reset on thz client side :
        pool_1
elseif { [class match [HTTP::header "online.protocol.remote.contenttype"] equals header_value_2] } {
        pool_2
    else {
        pool_3
        pool_1
        pool_2
    else {
        pool_3
