We have Requirement to Create Layer 7 Probe with blow String on F5 LTM
lriczupaswhd001.nam.pwcinternal.com:443/index.html
I am running IOS 13.1.3.4 .
Can SOme one Give Procedure and config Steps
Create custom HTTPS monitoring in F5 to monitor the page. Below command will help you to configure but basic troubleshooting needed per requirement.
# create ltm monitor https monitor_custom_https { defaults-from /Common/https send "GET /index.html HTTP/1.1\r\nHost: lriczupaswhd001.nam.pwcinternal.com\r\nConnection: Close\r\n\r\n" recv 200 }
Below will be output after monitor creatation.
adaptive disabled
defaults-from https
destination *:*
interval 5
ip-dscp 0
recv 200 # Change the string per requirements.
recv-disable none
time-until-up 0
timeout 16
. This is just an reference. myF5
