Hi everyone, I have web app. which is used for record some data to database. When i add some data such as name, city, country with Turkish character (ö,ğ,ü,ı,ş,ç), everything seems to be ok. However, When i make query from database, i could not display the char. correctly.
Merhaba arkadasim, ne haber?
I think you’ll need to do something with charsets. For example see this link:
Could you provide some more information? What database are you using? How does it relate to the F5 BIG-IP?
Kendine iyi bak!
This does not seem to be a question related to F5.
Jie, this is related with F5, because, when client connected backend server directly everything ok.
TayF5un, as Niels is already requesting please explain how the BIG-IP is involved in this. If it is just load balancing (LTM) i really doubt character sets come into play, but if you are using something like ASM then things get interesting.
so please share the setup.
Thank you all, I have solved the problem which is related with app. :)![]()
