scenario is User(access with certificate - self signed ) --- > LB (L4 forward) --- > Backend server with certificate (self signed)
when LB does L4 forward and when tried to connect with certificate, it says invalid certificate as its not in LB, how to bind certificate as well as use L4 forward. pls help
Is the user authenticated with a client certificate, or do you user the F5 for SSL decprytion and encryption?
If you want the use the F5 to decrypt and encrypt traffic, you need a Standaard virtual server. See;
K12015: Configuration requirements for SSL virtual servers, profiles, pools, and monitors
If the client authenticates to the back-end server with a certificate and you get a invalid certificate (which is not strange with self-signed certificates), you can take a look at the root CA’s on client and server.
Maybe you can give us more details about your setup?
