Kerberos/GSSAPI
I am load balancing our icewarp mail servers. SMTP is set to use port 465 for secured and is using kerberos/GSSAPI. Our F5 LTM is not part of the external mail domain. I’ve got POP working with SSL, as is SMTP over 25. As soon as I switch to secured on port 465 for SMTP it says the kerberos ticket did not match what it got back from the server. Unfortunately, I am doing this in a test environment wherein the ip does not yet resolve to anything so our cert will obviously not work until I register the name. What I am asking is, is there anything special I need to do to permit kerberos authentication as far as auth profiles and irules? I am assuming so. And will this work without the F5 being part of the domain against which these tickets are authenticating? It seems to communicate with it anyway as it knows enough that the kerberos ticket is invalid. Thanks anyone for any ideas.
Why do you say this? Where are you seeng the error messages? Can I also assume you’re not using the APM or ACA modules for Kerberos proxy on the LTM?
