kerberos APM
I found the following Ask F5 article - https://support.f5.com/kb/en-us/products/big-ip_apm/manuals/product/apm-aaa-auth-config-11-1-0/4.html. It provided a task list that noted the following: Joining a domain The client must be joined and connected to a domain if the Kerberos method is used. From the System Properties on a client machine, check to make sure the following parameters are set: domain controller, client machine, and APM vip. 1. Where would AMP VIP be found in System Properties? 2. How would it get there if APM not previously used for access?
Thanks.
I don’t think you have to check for the APM vip in your System Properties. The vip should be in DNS with the same name as the principal name (without the HTTP/)
Cheers,
Kees
to honest that whole line doesn’t make much sense, are you actually using version 11.1? you better look at later similar documents, the later ones seem to correct some errors in the old ones.
