Whats the default Keep-Alive timer value & Idle-timeout value for ver 11.5? 1. LTM to Nodes (Pool Members). 2. LTM to Client.
This depends on the profiles you are using (tcp, tcp-lan-optimized, fastl4…). You can see all the timer settings for the profiles in use in the web interface.
