Junk characters in response
I am new to this community so please help me if I am posting this questions at the wrong place..
We have 2 SharePoint 2010 front end servers attached to BIG-IP Load Balancer which has been upgraded recently.. Post this upgrade we are seeing some jnk characters in between the HTML response and we beleive this has something to do with F5 load balancer because if I add the host entry pointing to specific front end server then this issue does not occure and I am getting the valid HTML response… Below are the header and body details of the response.. Please note that I have highlighted (BOLD) the junk characters that I am talking about…
POST http://somSite/SomeBrand/GlobalBrands/\_layouts/CreatePublishingPageDialog.aspx?IsDlg=1 HTTP/1.1
Accept: image/jpeg, application/x-ms-application, image/gif, application/xaml+xml, image/pjpeg, application/x-ms-xbap, application/vnd.ms-excel, application/vnd.ms-powerpoint, application/msword, */*
Referer: http://somSite/SomeBrand/GlobalBrands/\_layouts/CreatePublishingPageDialog.aspx?IsDlg=1
Accept-Language: en-IN
User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 6.1; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; MS-RTC EA 2; MS-RTC LM 8)
Content-Type: application/x-www-form-urlencoded
Accept-Encoding: gzip, deflate
Host: aq
Content-Length: 3671
Connection: Keep-Alive
Pragma: no-cache
Cookie: BIGipServerSharepoint2010-mconnect.app~Sharepoint2010-mconnect_pool=1419510282.20480.0000; NTLMconnpool=!+diIjQjuEYknjehsljFXcqiMmYatoY7/Rw7qVOwIlOw9BH5Ydsj/Brr4QOBNr1PtSbjyD4ePLQvKvJvEOPIqpsb6h/vFUTvBEQrqmlvbRp3TPIYowXx9oO7ttodQyiz7vfxXpPkKzCI=; previousLoggedInAs=; loginAsDifferentAttemptCount=
HTTP/1.1 200 OK
Cache-Control: no-cache
Pragma: no-cache
Content-Type: text/html; charset=utf-8
Expires: -1
Server: Microsoft-IIS/7.5
SPRequestGuid: 95f979ed-30df-4ba3-9463-8e62bdfcd41d
X-SharePointHealthScore: 0
X-AspNet-Version: 2.0.50727
X-Powered-By: ASP.NET
MicrosoftSharePointTeamServices: 14.0.0.6123
X-MS-InvokeApp: 1; RequireReadOnly
Date: Tue, 26 Feb 2013 07:52:28 GMT
Vary: Accept-Encoding
Content-Length: 2486
7b5
“http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd”>
</div> <div>Processing…</div> <div>
Processing…
Please wait while your changes are processed.
20
105
0
Can someone please help me to diagnost this issue ?
Thanks in Advance
can you try to set “Response Chunking” setting in http profile to “Rechunk”?
Thanks for your help… We have made the changes accordingly but still facing the same issue, do we need to restart the load balancer, Server, Browser or clear the cookie to get this change into the effect ?
Thanks in advance
Ajay Sawant
do we need to restart the load balancer, Server, Browser or clear the cookie to get this change into the effect ?reboot should not be required for bigip and server. anyway, browser cache should be cleared. if it still does not help, i suggest you open a support case.
just my 2 cents
