JSESSIONID Persistence
I’m trying to persist off a JSESSIONID cookie generated by the WebLogic Application Server however the follow iRule isn’t working.
if { [HTTP::cookie exists “JSessionID”] } {
persist use [HTTP::cookie “JSessionID”]
Any help would be greatly appreciated.
Thanks,
Christopher G Davis
Sr. Network Engineer
SITA Atlanta Data Center
Chris -
Take a look here:
http://devcentral.f5.com/wiki/default.aspx/iRules/Weblogic\_JSessionID\_Persistence.html
Click here
Thanks I’ll give it a go…
--cd
See below for name references.
The JSession persistence appears not to work unless I add Source Address Affinity as a fallback. I check the persistence table before adding and no entry was made for “cce-jsession-http”. Furthermore, I checked the pool members and one attempt to the url is spreading traffic across all pool members. After adding cce-jsession-addre-http I see an entry in the persistence table and one attempt to the url is being sent to one member in the pool.
Is this correct behavior?
Below I’ve included the ip header with the JsessionID and the configuration I’m using.
GET /cce-presentation-kiosk-tg/branding/tg/client/Production/css/pleaseWait.css;jsessionid=zytPJpxV0TnpssqZZRLBgsVMLhGS6M2ZNMZ622yCNvpv0gkpTwzn!956498630 HTTP/1.1
Accept: */*
Referer: http://selfservice-uat.sita.aero/cce-presentation-kiosk-tg/entryUpdate.do
Accept-Language: en-us
UA-CPU: x86
Accept-Encoding: gzip, deflate
User-Agent: Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; InfoPath.1; .NET CLR 2.0.50727)
Host: selfservice-uat.sita.aero
Connection: Keep-Alive
Cookie: JSESSIONID=zytPJpxV0TnpssqZZRLBgsVMLhGS6M2ZNMZ622yCNvpv0gkpTwzn!956498630
virtual VS-CCE_QA_http {
fallback persist cce-jsession-addre-http
destination 10.9.16.34:http
ip protocol tcp
rules cce-direct-http
profiles
http
oneconnect
tcp
persist cce-jsession-http
profile persist cce-jsession-http {
defaults from universal
mode universal
timeout 180
rule cce-presist-http
rule cce-presist-http {
persist uie [HTTP::cookie “JSessionID”]
set jsess [findstr [HTTP::uri] “JSessionID” 11 “;”]
if { $jsess != “” } {
persist uie $jsess
when HTTP_RESPONSE {
persist add uie [HTTP::cookie “JSessionID”]
profile persist cce-jsession-addre-http {
defaults from source_addr
mode source addr
timeout 30
rule cce-direct-http {
if { [HTTP::uri] starts_with “/cce-presentation-kiosk-a3/”} {
pool CCE_A3_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-kiosk-fv/”} {
pool CCE_FV_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-web-fv/”} {
pool CCE_FV_WCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-kiosk-ma/”} {
pool CCE_MA_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-web-ma/”} {
pool CCE_MA_WCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-kiosk-mh/”} {
pool CCE_MH_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-web-mh/”} {
pool CCE_MH_WCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-kiosk-lg/”} {
pool CCE_LG_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-web-lg/”} {
pool CCE_LG_WCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-kiosk-lx/”} {
pool CCE_LX_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-web-lx/”} {
pool CCE_LX_WCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-kiosk-sp/”} {
pool CCE_SP_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-web-sp/”} {
pool CCE_SP_WCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-kiosk-tg/”} {
pool CCE_TG_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-kiosk-un/”} {
pool CCE_UN_KCI
} elseif { [HTTP::uri] starts_with “/cce-presentation-web-un/”} {
pool CCE_UN_WCI
log local0. “URI doesn’t match; rejecting connection http://[HTTP::host][HTTP::uri]”
reject
Thanks,
Christopher G Davis
Hi Chris,
There are a few possible issues with the Codeshare example:
1. The cookie name for HTTP::cookie is case sensitive. So [HTTP::cookie JSessionID] won’t match a cookie named jsessionid or JSESSIONID. I believe that the jsessionid name is always in lower case, whether set in the path or a cookie name.
2. findstr is also case sensitive.
3. The format for the jsessionid in the URI is /path/to/object.ext;jsessionid=jsessionid_value or with a query string /path/to/object.ext;jsessionid=jsessionid_value?param=param_value. So using findstr with a terminator of ; won’t work as expected. If you were checking the URI with a terminator, it should be the ? which starts the query string. Considering the jsessionid, if present, will always be at the end of the path, you can avoid dealing with a terminator by using HTTP::path insted of HTTP::uri.
4. The findstr command needs to account for the = in jsessionid=12345…, so it should be [findstr [HTTP::path] “jsessionid=” 11]
Can you try this example which addresses the above points? If you run into problems, please check the /var/log/ltm log file for debug output. Once you’re done testing, youc can comment out the log statements. If it does work, please reply so we can update the Codeshare example.
Thanks,
Aaron
      Log details for the request
     log local0. "[IP::client_addr]:[TCP::client_port]: Request to [HTTP::uri] with cookie: [HTTP::cookie value jsessionid]"
      Check if there is a jsessionid cookie
     if { [HTTP::cookie exists "jsessionid"] } {
         Persist off of the cookie value
        persist uie [HTTP::cookie "jsessionid"]
         Log that we're using the cookie value for persistence and the persistence key if it exists.
        log local0. "[IP::client_addr]:[TCP::client_port]: Used persistence record from cookie: [persist lookup uie [HTTP::cookie "jsessionid"]]"
         Parse the jsessionid from the path (URI minus the query string)
        set jsess [findstr [HTTP::path] "jsessionid=" 11]
         Use the jsessionid from the path for persisting
        if { $jsess != "" } {
           persist uie $jsess
            Log that we're using the path jessionid for persistence and the persistence key if it exists.
           log local0. "[IP::client_addr]:[TCP::client_port]: Used persistence record from path: [persist lookup uie $jsess]"
      Check if there is a jsessionid cookie in the response
        persist add uie [HTTP::cookie "jsessionid"]
        log local0. "[IP::client_addr]:[TCP::client_port]: Added persistence record from cookie: [persist lookup uie [HTTP::cookie "jsessionid"]]"
That appears to have fixed it.
I now see two entries in the persistence table one with the jsessionid as the “Persistence Value” and a second with “/” as the “Persistence Value” for the Source Address Affinity profile. However without the “Source Address Affinity” fallback traffic is still spread across all pool members.
With the fallback in place; when I test a second time before the two persistence entries timeout I’m sent to the same node, hence, my belief this is working.
Thanks,
--cd
Thanks for the confirmation. I updated the Codeshare example. Also, you can set the persistence timeout from the iRule and avoid the extra configuration step of adding a universal persistence profile.
Aaron
Actually, it looks like the cookie name is in all caps and the string in the URIs is all lower case. I’ve updated the Codeshare example with this. If you see differently in your installation, can you let me know?
Thanks,
Aaron
Hopefully it not to late to revisit this,
Here is the rule that in place now.
log local0. “[IP::client_addr]:[TCP::client_port]: Request to [HTTP::uri] with cookie: [HTTP::cookie value JSESSIONID]”
if { [HTTP::cookie exists “JSESSIONID”] } {
persist uie [HTTP::cookie “JSESSIONID”]
Log that we’re using the cookie value for persistence and the persistence key if it exists.
log local0. “[IP::client_addr]:[TCP::client_port]: Used persistence record from cookie: [persist lookup uie [HTTP::cookie JSESSIONID”]]"
set jsess [findstr [HTTP::path] “JSESSIONID” 11]
persist uie $jsess
Log that we’re using the path jessionid for persistence and the persistence key if it exists.
log local0. “[IP::client_addr]:[TCP::client_port]: Used persistence record from path: [persist lookup uie $jsess]”
persist add uie [HTTP::cookie “JSESSIONID”]
log local0. “[IP::client_addr]:[TCP::client_port]: Added persistence record from cookie: [persist lookup uie [HTTP::cookie “JSESSIONID”]]”
But I’m receiving errors, Any thoughs
Jan 30 16:52:02 tmm tmm[1616]: Rule cce-jsession-persist : 57.250.242.249:49297: Request to /cce-presentation-kiosk-tg/entryUpdate.do with cookie: fn2XJC1TL2sgBsz3XWnbrDMp49Dwd0nyhdQnSgn16hHqyDPJ0Lyk!779042597
Jan 30 16:52:02 tmm tmm[1616]: 01220001:3: TCL error: cce-jsession-persist - Prerequisite operation not in progress (line 1) invoked from within "persist lookup uie [HTTP::cookie “JSESSIONID”] "
Jan 30 16:53:49 tmm tmm[1616]: Rule cce-jsession-persist : 57.250.242.249:53325: Request to /cce-presentation-kiosk-tg/entryUpdate.do with cookie: fn2XJC1TL2sgBsz3XWnbrDMp49Dwd0nyhdQnSgn16hHqyDPJ0Lyk!779042597
Jan 30 16:53:49 tmm tmm[1616]: 01220001:3: TCL error: cce-jsession-persist - Prerequisite operation not in progress (line 8) invoked from within "persist lookup uie [HTTP::cookie “JSESSIONID”] "
Hi Chris,
I’m not sure why you’d be seeing this error. Typically it’s seen when there isn’t a default pool on the VIP. However, I assume you already have a pool on the VIP as it’s not being specified in the iRule. Is this the case? Do you have any other iRules added to the VIP? If so, can you post an anonymized copy?
If you do have a default pool and no other iRules, you might try opening a case with F5 Support to ask them to help troubleshoot the issue. If you find anything via this route, could you reply back here?
Thanks,
Aaron
FWIW, there actually doesn’t seem to be a default pool defined in the originally posted VS config above…
