JSESSIONID Cookie failover
Hello,
I was wondering if anyone has some examples of a i-rule to persist on primary and secondary nodes for Weblogic v10. I seen some older posts on doing this but they where using jsession uri, We use JSESSION cookies.
Thanks,
Have you had a look at this? http://devcentral.f5.com/Wiki/default.aspx/iRules/Weblogic\_JSessionID\_Persistence.html
-Matt
Matt,
I have an I-rule that I wrote to successfully persist on JSESSIONID. The issue I am having is that we mirror our weblogic sessions to a fallback server. In order to use this fallback feature while loadbalancing your bea servers with F5 is being able to write an i-rule to grab the JSESSIONID and split it into 3 values cookie, Primary Server, Secondary Server. The catch is that the Primary and Secondary Server Ip, Port is hashed. I’m not real sure that there is a way to decode this hash. So my next thought was to figure out what hash value goes with what IP and hardcode those ip’s in the i-rule. The only problem with this is that the hash values change every time you restart the server so that is not a good solution.
My question is has anyone seen this, or have been down this road successfully or unsuccesfully.
Thanks,
Brett
Hi Brett,
Can you post a few examples of the cookie values and which primary and secondary server IP’s/ports they correspond to?
You could potentially try to use a similar method as this example--just change the parsing of the value from the URI to the cookie and replace some of the regexp commands with string functions:
http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=18948
Thanks,
Aaron
Unfortunately I cannot provide that information being that I work on a restricted site. I have looked at the i-rule you are referencing and it would work if only I can decode the hash to Ip Addresses.
-Brett
Hi Brett,
If the ID’s are true one way hashes, it actually wouldn’t actually help to see examples.
I wonder if the server which sets the cookie always lists itself as the first node in the jsessionid cookie value? If so, you could keep a mapping of the current hashes and work out which server IP:port a secondary hash corresponds to once that server had set a cookie.
Load Balancers and the WebLogic Session Cookie
http://download.oracle.com/docs/cd/E11035\_01/wls100/cluster/load\_balancing.htmlwp1028843
The format of a session cookie is:
sessionid!primary_server_id!secondary_server_id
where:
* sessionid is a randomly generated identifier of the HTTP session. The length of the value is configured by the IDLength parameter in the element in the weblogic.xml file for an application. By default, the sessionid length is 52 bytes.
* primary_server_id and secondary_server_id are 10 character identifiers of the primary and secondary hosts for the session.
Note: For sessions using non-replicated memory, cookie, JDBC, or file-based session persistence, the secondary_server_id is not present. For sessions that use in-memory replication, if the secondary session does not exist, the secondary_server_id is “NONE”.
If that seems plausible, let me know and I’ll try to come up with a rough version for you to try testing. Also, can you confirm which LTM version you’re running?
Thanks,
Aaron
Aaron,
I like where you going with this. You are correct the server that sets the cookie is always the primary server. I am only concerned about one issue of your purposed solution and maybe that it’s not an issue at all and I just am not fully understanding what you mean by mapping. I am assuming that you are meaning hard code the ip:port to a corresponding hash value in the i-rule. If this is the case for some reason if you reboot, restart or shutdown the bea services this hash value changes. Now why I’m not exactly sure, I would think that the hash would be the same as long as the value it’s hashing does not change, but this is not the case.
If you could show me a rough draft that would be excellent.
Thank you for you support.
-Brett
Hi Brett,
Can you confirm which LTM version you’re using? The options for session table entries vary between 9.x and 10.x.
Thanks,
Aaron
Aaron,
We are currently running 10.0.1 Build 354.0 HF2. But I am testing 10.1 currently and I’m hoping if all goes well to move to it soon.
Thanks again.
-Brett
Could you wait for 10.1 to implement the iRule using the table command (Click here)? In the meantime, you could use cookie insert persistence as a simple way to handle persistence to the primary node (which wouldn’t support failover to the secondary pool member)?
If not, I can try a version using the session command in 10.x.
Aaron
Aaron,
10.1 will be fine, I’m running it on my NOE and plan to move it soon to the OE.
-Brett
Great. I’ll try testing something in the next few work days and get back to you.
Aaron
I tested an initial version using UIE persistence without the session table. Logically it looks good, but when testing TMM cores. I need to see if it’s a logic error on my part or an unavoidable bug. I’ll let you know how it goes.
Aaron
Aaron,
No problem, thank you for you support.
-Brett
So this is the first version of the rule that I was testing. It seems to crash TMM when either adding or looking up the UIE persistence records. Don’t try this on a production system! But if you have a test unit, could you see if you get any different results? I’ll open a case with F5 and see if they can determine what the problem is.
Aaron
[edit: see below for an updated version]
Aaron,
I appreciate it I will test this out in next couple weeks when I get availability to the dev environment. I apologize for taking so long to respond, I have been out of the office. I will let you know how it works. Again I deeply appreciate your help and time.
-Brett
No worries. Let me know how the testing goes.
Thanks, Aaron
Aaron,
Thanks for you help. I have been working with support as well and had pointed this thread to them. My issue is that I’m still on 9.2.5. Support told me that the code installed and didn’t error out. I’m going to try and test it during our next maintenance schedule. Hope it works out for Brett.
Thanks,
I can’t see any reason the rule wouldn’t work on 9.2.5. Originally I was thinking of using the table command (added in 10.1.0), but UIE persistence seemed like a cleaner solution anyhow.
It would be a good idea to upgrade to a supported version when you’re able to. 9.3.1 would be a quick, safe change. 10.0.1 with the latest hotfix would be a better long term solution. Or you could use 10.1.0 once a hotfix or two are released.
Aaron
Hoolio,
I apologize for the delay. I have finally been able to test this i-rule. It is working very well as far as I can see. I want to thank you for your time and help. You have been more then helpful, Thank you.
--Brett
