I am attempting to integrate LTM with a web application that uses a cookie based jsessionid somehow during the login process that the F5 is not handling.
To explain, when I browse to the site through the F5, with cookies turned off in my browser, I can see a jsessionid parameter in the address field, and can log in.
When I switch cookies back on in my browser, I no longer see the jsessionid in the address field, but when I attempt to login to the application, the browser is redirected back to the login page.
When I try the same process while browsing directly through to the node, the login works with or without cookies enabled.
There is only one node so I dont believe it is a persistence issue. Any help would be greatly appreciated.
Cheers
Josh
