I have issue with my application, my web application is published with f5 https offload. The web application is working normally, but same page like generate report, web not loaded and not show the report. if i inspect on the web browser it’s raise the error like :
Debug.js:45 Uncaught SyntaxError: missing ) after argument list head.js:5 Uncaught SyntaxError: Unexpected token ) BirtSoapRequest.js:128 Uncaught ReferenceError: debug is not defined AbstractBaseDialog.js:175 Uncaught ReferenceError: debug is not defined
Please Help to solve this issue.
Hello is you application working with https server side or http ? could you give us a link to the site ?
Dear Sir,
I am also facing same problem,
I have an application, and did the below steps: 1. created VS with port 80 (as original application) 2.Created another VS with port 443 and added the https_redirection rule 3.Application is working fine over when we generate a report then it does not work. 4. I went to Security ›› Event Logs : Application : Event Correlation -- found that, attack type - XML Parser Attack Violations - Malformed XML data
therefore kindly request you to help me to fix this.. here are my F5 details: F5-BIG-IP ASM with 13.0 Build2
thank you Regards,
