Hello,
I am trying to setup a reverse proxy for the application written with socket.io which tries to upgrade the connection to Secure Websockets. Looking at the docs WSS should be supported in BIG-IP 11.5.4, however I am getting some connection errors as per below (trace from the Firebug):
The connection to wss://host.example.com/launchpad/socket.io/?EIO=3&transport=websocket&sid=GTQLD62vWeuwQwIzAAIp was interrupted while the page was loading. socket.io.js (line 3, col 1049)
Are there any limitations known when using LTM and WSS ? In my existing lab configuration I am using both rewrite rules and stream profiles to rewrite URLs.
Thanks a lot for any comments Regards
