if you just want to change http host header in request only, you can use HTTP::header replace command but if support.3rdpartywebsite.com is also embedded in response body (so, you have to rewrite it back to support.yourdomain.com), you may need to use proxypass which Mark suggested.
e.g.
config
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.10:80
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
http { }
tcp { }
rules {
qux
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 19
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
members {
200.200.200.101:80 {
address 200.200.200.101
root@(ve11c)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
if { [HTTP::host] eq "support.yourdomain.com" } {
HTTP::header replace Host "support.3rdpartywebsite.com"
trace
[root@ve11c:Active:In Sync] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.24.1(53863) <-> 172.28.24.10(80)
1427071308.3080 (0.0279) C>S
GET /someting HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Accept: */*
Host: support.yourdomain.com
New TCP connection 2: 200.200.200.14(53863) <-> 200.200.200.101(80)
1427071308.3122 (0.0030) C>S
Accept: */*
Host: support.3rdpartywebsite.com
