Hello, I have configured VIP with specific SNAT. snat IP is other than the LAN subnet. VIP works with AUTOMAP, however when specific SNAT configure is do not work,
below is the config of VIP.
virtual r_vs_agr {
snat automap
pool Pool_AGR
destination 10.155.65.39:https
ip protocol tcp
persist persist_sso
profiles {
http_sso {}
r_clientssl_uat-sso {
clientside
serverssl {
serverside
tcp {
clientside
tcp-lan-optimized {
serverside
vlans INTERCO enable
pool Pool_AGR {
lb method member observed
monitor all my_http_GET and tcp_halfopen_8446
members {
10.155.51.29:8446 {}
10.155.51.30:8446 {}
10.155.51.53:https {}
10.155.51.54:https {}
When I configure SNAT with an IP of 10.155.70.x range VIP becomes non accessible.
I also checked on pool nodes for route and found default route pointing to my core switches from which SNAT IP is accessible with source IP.
I dont understand, why it is not working with specific SNAT if it works with AUTOMAP. which IP VIP takes to communicate with nodes if automap is configured for VIP?
Automap will use the floating Self IP of the VLAN used to communicate with the Pool Members.
What configuration are you using when you assign a specific SNAT IP? Can you post that too?
Regarding routing, are you sure the return traffic is being routed back to the F5 when you use the specific IP? That’s normally where the issue lies. Without understanding the VLAN and routing infrastructure further it’s hard to comment more.
When I configure SNAT with an IP of 10.155.70.x range VIP becomes non accessible.how did you configure the snat? would you mind posting the snat configuration you used?
I just met the similar problem.What do you mean by self IP which was not allowing to perform HTTP action?Could you please tell me more about it and the solution?Thx in advance.
