We want to set up a https virtual server with the following characteristics:
- service port 443
- Protocol: tcp
- Type: performance (Layer 4)
- source address default persistence profile
- SNAT automap
Our code (below) works, except that the virtual server is configured as a standard virtual server. I would greatly appreciate it if you could glance at this code…Do you see anything here that prevents it from being set up as a fast L4?
public void createHttpsVirtualServer(final String name, final String ip, final long port, final String poolName) throws LoadBalancerException {
CommonVirtualServerDefinition vsDef = new CommonVirtualServerDefinition(name, ip, port, CommonProtocolType.PROTOCOL_TCP);
final CommonVirtualServerDefinition[] definitions = new CommonVirtualServerDefinition[]{vsDef};
final String[] wildmasks = new String[]{“255.255.255.255”};
final LocalLBVirtualServerVirtualServerResource resource = new LocalLBVirtualServerVirtualServerResource(LocalLBVirtualServerVirtualServerType.RESOURCE_TYPE_FAST_L4, poolName);
final LocalLBVirtualServerVirtualServerResource[] resources = new LocalLBVirtualServerVirtualServerResource[]{resource};
final LocalLBVirtualServerVirtualServerType[] serverTypes = new LocalLBVirtualServerVirtualServerType[]{LocalLBVirtualServerVirtualServerType.RESOURCE_TYPE_FAST_L4};
LocalLBVirtualServerVirtualServerPersistence profile = new LocalLBVirtualServerVirtualServerPersistence();
profile.setProfile_name(“fastL4”);
final LocalLBVirtualServerVirtualServerProfile[][] profiles = new LocalLBVirtualServerVirtualServerProfile[][]{{}};
try {
getLbInterface().getLocalLBVirtualServer().create(definitions, wildmasks, resources, profiles);
} catch (Exception ex) { throw new LoadBalancerException(ex);
