We’re setting up two virtual servers with the same parent rate class, to limit their aggregate traffic.
Our first step in iControl is to create the parent rate class, then set up each child rate class and assign them the parent.
Based on the tutorial example:
our first step was to create the rate class using the create method LocalLB.RateClass.create
However, when we create a rate class with 0 base rate, the F5 responds with the error:
Exception: Common: OperationFailded
primary_error_code : 17236601 (0x01070279)
secondary_error_code: 0
error_string : 01070279:3: Rate class ‘parentRateClass_3’: ceiling rate must be greater than or equal to 296bps
At that point, we haven’t specified the ceiling rate. The base rate is set to 0 MBps.
See anything? thx.
