Issue with Restnoded Daemon
Hello,
When login SSH to one of my LTM Nodes I receive the bellow Alert that appears on terminal recursively : “emerg logger: Re-starting restnoded”
Can I know what’s causing the restart of this daemon?
thx
When swaping all to Standby Device, The message disappears (on the 2nd node)
It seems the issue is impacted only one node.
The impacted node continues to send message, even when it is in standby mode.
I have the same issue for my Ltm, could you please share What is the workaround for this?
Are you dealing with iWorkflow in your solution?. Maybe this could help https://devcentral.f5.com/wiki/iWorkflow.HowToSamples_iworkflow_js_samples.ashx (Check section 3. “Run and manage the sample code on restnoded”)
