I am using the common iRule for setting the secure cookie flag on each cookie-
when HTTP_RESPONSE {
set cookies [HTTP::cookie names]
Loop through each cookie by name in request
foreach aCookie $cookies {
Replace cookie name from list and set Secure Flag to Enable
HTTP::cookie secure $aCookie enable
The issue comes up when there is a cookie whose data has a space in it. The iRule appears to truncate the cookie at the space.
cookie=CGI&SPONSOR_UserRole=Information Services&SPONSOR
Any thoughts on how to met the iRule to process this cookie correctly?
Thanks-
Mike
Well, it looks like the space breaks it reading the cookie. I changed the irule to log the cookie instead of add the flag and I see a cookie with name Services&SPONSOR (the text after the space. Is there any way to work around this on the F5 or will it have to be a change in the site?
Mike
If you add in some logging, what do you see?
log local0. "$aCookie = [HTTP::cookie value $aCookie]"
What F5 version are you on?
nitass
July 22, 2013, 9:51am
4
The issue comes up when there is a cookie whose data has a space in it. i thought cookie value does not contain whitespace.
HTTP cookie
An HTTP cookie (also called web cookie, Internet cookie, browser cookie, or simply cookie) is a small block of data created by a web server while a user is browsing a website and placed on the user's computer or other device by the user's web browser. Cookies are placed on the device used to access a website, and more than one cookie may be placed on a user's device during a session. Cookies serve useful and sometimes essential functions on the web. They enable web servers to store stateful in...
anyway, it seems okay to me here.
e.g.
[root@ve10:Active] config b version|grep -iA 1 version
BIG-IP Version 10.2.4 655.0
Hotfix HF4 Edition
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.252:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve10:Active] config b pool foo list
pool foo {
members 200.200.200.101:80 {}
[root@ve10:Active] config b rule myrule list
rule myrule {
log
[root@ve10:Active] config cat /var/log/ltm
Jul 22 17:29:54 local/tmm info tmm[26228]: Rule myrule : cookie = CGI&SPONSOR_UserRole=Information Services&SPONSOR
trace
[root@ve10:Active] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.20.17(47282) <-> 172.28.19.252(80)
1374485394.6293 (0.0010) C>S
HEAD / HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
Host: 172.28.19.252
Accept: */*
New TCP connection 2: 200.200.200.10(47282) <-> 200.200.200.101(80)
1374485394.6321 (0.0010) C>S
HEAD / HTTP/1.1
Host: 172.28.19.252
Accept: */*
1374485394.6353 (0.0031) S>C
HTTP/1.1 200 OK
Date: Mon, 22 Jul 2013 09:40:26 GMT
Server: Apache/2.2.3 (CentOS)
Last-Modified: Thu, 23 May 2013 00:28:46 GMT
ETag: "4185a8-59-c3efab80"
Accept-Ranges: bytes
Content-Length: 89
Set-Cookie: cookie=CGI&SPONSOR_UserRole=Information Services&SPONSOR
Connection: close
Content-Type: text/html; charset=UTF-8
1374485394.6354 (0.0060) S>C
HTTP/1.1 200 OK
Content-Length: 89
Set-Cookie: cookie=CGI&SPONSOR_UserRole=Information Services&SPONSOR;secure;
Connection: close
Running 11.3.0.
I did add some logging and found that it was show a cookie with the name containing the text after the space in the first cookie.
With the string you are using to test add = to the string, so it would look something like
SRS0=CGI&SPONSOR_UserRole=Information Services&SPONSOR_MLID=iaGgsohWthE%2BNvC
Mike
nitass
July 22, 2013, 2:14pm
7
i think the correct way is to fix cookie value at server.
anyway, if there is small number of cookie value containing space, you may temporarily remove (space) and add it back after securing cookie.
e.g.
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm virtual bar15
ltm virtual bar15 {
destination 172.28.20.15:80
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
http { }
tcp { }
rules {
myrule
source 0.0.0.0/0
source-address-translation {
type automap
vlans-disabled
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm pool foo
ltm pool foo {
members {
address 200.200.200.101
root@(ve11a)(cfg-sync Changes Pending)(Active)(/Common)(tmos) list ltm rule myrule
ltm rule myrule {
remove space
set cklist [HTTP::header values Set-Cookie]
HTTP::header remove Set-Cookie
foreach ck $cklist {
HTTP::header insert Set-Cookie [string map {"Information Services" "InformationServices"} $ck]
secure cookie
foreach aCookie [HTTP::cookie names] {
add space
HTTP::header insert Set-Cookie [string map {"InformationServices" "Information Services"} $ck]
original response
[root@ve11a:Active:Changes Pending] config curl -I http://200.200.200.101
HTTP/1.1 200 OK
Date: Mon, 22 Jul 2013 14:06:26 GMT
Content-Length: 89
Set-Cookie: SRS0=CGI&SPONSOR_UserRole=Information Services&SPONSOR_MLID=iaGgsohWthE%2BNvC
Set-Cookie: EPowerV4Users=carrefourvoyagesb2b=13_user; path=/; secure
Connection: close
response after passing bigip
[root@ve11a:Active:Changes Pending] config curl -I http://172.28.20.15
HTTP/1.1 200 OK
Date: Mon, 22 Jul 2013 14:06:35 GMT
Content-Length: 89
Connection: close
Set-Cookie: SRS0=CGI&SPONSOR_UserRole=Information Services&SPONSOR_MLID=iaGgsohWthE%2BNvC;secure;
