BIG-IP 11.3.0 Build 3093.0 Hotfix HF4
We are trying to direct traffic for a specific path if you are a member of the datagroup. Here is the iRule :
if { ([HTTP::path] starts_with “/SalesEntrySystem”) and ! ([class match [IP::remote_addr] equals $::SES]) } {
pool Pool_SES_LINK
However, it is not working and we are seeing this error in the LTM logs:
TCL error: /Common/SES - can’t read “::SES”: no such variable while executing “class match [IP::remote_addr] equals $::SES”
Any suggestions?
Thanks!
You don’t need the “$::” syntax with the class commands. Assuming your data group is called “SES”, then it’s just:
if { ([HTTP::path] starts_with “/SalesEntrySystem”) and ! ([class match [IP::remote_addr] equals SES]) } {
Where are you setting the SES variable?
Thanks Kevin. We tried removing the “$::” . We don’t get the error any longer however, it doesn’t redirect.
We’ve got the data group setup with a few test IPs. Mine and my coworker’s but neither redirect to the pool. Would we need an “ELSE” statement?
By redirect, I mean use the pool we set.
I’d make a few minor modifications and retest:
log local0. "URI = [string lower [HTTP::uri]]"
log local0. "Client IP = [IP::client_addr]"
if { ( [string tolower [HTTP::uri]] starts_with "/salesentrysystem") and not ( [class match [IP::client_addr] equals SES] ) } {
pool Pool_SES_LINK
Check the logs and make sure the request URI and client IP both match your conditions. On a side note, can I assume you want to allow this pool redirect ONLY if the user requests /salesentrysystem* AND the client IP is IN the data group? If so then I would remove the not operator.
