Hey guys, I am having an issue with an irule that I got from code share that is shown below. This irule is used on 2 virtual servers (using the same nodes, but different ports) and should be persistent between virtual servers. The user logs into the website, which is vs 1, and clicks a link that sends them to vs 2 (the same node). This works only sometimes for the users. The HTTP::response event in this irule always works, but the HTTP::request event gets numerous errors.
Here’s the error:
Aug 19 16:18:57 local/tmm err tmm[13657]: 01220001:3: TCL error: cookie - no such pool Failed Tcl_pool_GetFromObj: pool (line 6) invoked from within “active_members -list [LB::server pool]”
IRule:
if { [HTTP::cookie exists “cookie”] } {
set decrypted [HTTP::cookie decrypt “cookie” “passcode”]
if { ($decrypted ne “”) }
{ set persist_node [HTTP::cookie “cookie”]
foreach member [active_members -list [LB::server pool]] { <--Line that fails
I’m not sure I see how your iRule would work… However, a couple of things I notice…
1. The cookie is encrypted, yet you use the actual cookie value directly in
set persist_node [HTTP::cookie "cookie"]
which means the node $persist_node […] is going to fail too…
shouldn’t that be
set persist_node decrypted
or simply replace ‘decrypted’ with ‘persist_node’…
2. Why are you looping through the poolmembers?
3. What happens if the cookie exists already but wasn’t actually set by the iRule HTTP_RESPONSE?
I think you need to catch {} any errors from the decrypting too… Otherwise bad cookies will kill your connection… Are there any other errors (Sorry, I don’t have my stuff with me to actually test your iRule on an LTM).
What’s your default pool called? Your TCL error leads me to believe the rule is somehow looking for a pool called “cookie”
What version are you running?
The reason you aren’t seeing anything for logging LB::server is because you haven’t chosen a server which makes me think your default pool isn’t specified.
I am using this irule for 3 different virtual servers. Each vs has a default pool defined (same nodes, but different ports). We are running version 10.0.1.
I don’t really have the need for an encrypted cookie, but this is the closest codeshare example I could find to what I wanted to do.
May I ask what the name of the default pool is for the VS that is giving you this error?
there would be 2 default pools, p_lum_test and p_lum_resource_test. one pool is used by one virtual server and one pool is used by 2 other virtual servers. i want to persist across all 3 virtual servers.
according to the article, i would have to be using the same pool for all 3 virtual servers?
Can you add this to the bottom of your HTTP_RESPONSE event?
log local0. “cookie value set to [IP::remote_addr]”
Let’s kill the encrypt/decrypt logic and make the rule look like this:
If the cookie exists, connect to the IP specified in the cookie
if { [HTTP::cookie exists "cookie"] } {
if { ([HTTP::cookie "cookie"] ne "") } {
set node [lindex $member 0]
if { $node eq $persist_node } {
node $persist_node [lindex $member 1]
when LB_FAILED {
LB::reselect
when HTTP_RESPONSE {
HTTP::cookie insert name "cookie" value [IP::remote_addr] path /
Optionally comment out the above line and use the following line
instead while specifying a domain
HTTP::cookie insert name "cookie" value [IP::remote_addr] path / domain abc.com
Ok, I tried the rule you have above. The user can log into the web portal fine, there is a link on the portal that sends the user to the port 8008 virtual server. Sometimes it works, and sometimes it just hangs. The virtual servers are listed below, and the 2 physical servers are 10.10.11.252 and 10.10.11.253.
here is the output from the log we put in the HTTP_RESPONSE event:
Aug 26 15:53:29 local/tmm1 info tmm1[13658]: Rule persist_prod : cookie value set to 10.10.11.252
I’m still getting the TCL error in the line: foreach member [active_members -list [LB::server pool]] {
Should/could we include both pools in the LB::server function somehow?
What about an irule that grabs the IP::remote_addr from the http_response when the user hits the vs_HTTPS vs, and apply the rule to the 8008 vs, having them hit the same server thats returned by the IP::remote_addr? Is there a way we could do that?
Ug…this is what I get for posting before I’m completely awake…I see you already configured logging and that you’re inserting the cookie properly.
Under this line:
Add:
log local0. "$persist_node set to [HTTP::cookie "cookie"]"
Let me know what that’s giving you…want to make sure the cookie is coming in properly…somehow, the LB::server pool command is having issues. Can you paste the exact TCL error you’re getting now?
log local0. “$persist_node set to [HTTP::cookie “cookie”]” is returning this:
Aug 27 09:39:19 local/tmm1 info tmm1[13658]: Rule persist_prod : 10.10.11.252 set to 10.10.11.252
The TCL error is:
Aug 27 09:37:24 local/tmm err tmm[13657]: 01220001:3: TCL error: persist_prod - no such pool Failed Tcl_pool_GetFromObj: pool (line 1) invoked from within “active_members -list [LB::server pool]”
Aug 30 09:31:01 local/tmm info tmm[13657]: Rule persist_prod : persist_node is 10.10.11.252 and server pool is p_webpool
when the user initiates connection to the other vs:
Aug 30 09:32:02 local/tmm info tmm[13657]: Rule persist_prod : persist_node is 10.10.11.252 and server pool is p_Resource_8008
it looks like the node is staying persistent between pools, but it is still giving me the TCL error:
Aug 30 09:36:56 local/tmm err tmm[13657]: 01220001:3: TCL error: persist_prod - no such pool Failed Tcl_pool_GetFromObj: pool (line 1) invoked from within “active_members -list [LB::server pool]”
Just for kicks…please change your request event to this:
log local0. "persist_node is $persist_node and server pool is [LB::server pool]"
set current_pool [LB::server pool]
foreach member [active_members -list $current_pool] {
This is less efficient as we’re setting a variable for the selected pool, but I’m curious.
I see the same result…it’s logging the same information as my last post, but the TCL error still exists:
Aug 30 15:32:15 local/tmm1 err tmm1[13658]: 01220001:3: TCL error: Luminus_persist_prod - no such pool Failed Tcl_pool_GetFromObj: pool (line 1) invoked from within “active_members -list $current_pool”
one thing i did notice in the log is that both pool members were being used, see below: (these are consecutive lines)
and in the 5th entry shown, LB::server is blank
Aug 30 15:32:14 local/tmm1 info tmm1[13658]: Rule persist_prod : persist_node is 10.10.11.252 and server pool is p_HTTPS
Aug 30 15:32:14 local/tmm1 info tmm1[13658]: Rule persist_prod : cookie value set to 10.10.11.253
Aug 30 15:32:14 local/tmm1 info tmm1[13658]: Rule persist_prod : cookie value set to 10.10.11.252
Aug 30 15:32:15 local/tmm1 info tmm1[13658]: Rule persist_prod : persist_node is 10.10.11.252 and server pool is
Aug 30 15:32:15 local/tmm1 err tmm1[13658]: 01220001:3: TCL error: persist_prod - no such pool Failed Tcl_pool_GetFromObj: pool (line 1) invoked from within “active_members -list $current_pool”
